Activity › Forums › Apple Final Cut Pro Legacy › wanting to add I/O device
  • wanting to add I/O device
    Posted by Cy Chadwick on September 22, 2005 at 10:28 pm
    Running FCP5 I use a G5 dual 2 gig with 4 gig ram. I want to plug up my sony studio monitor but without loooping through the DSR20 deck. Any thoughts on hardware? I’m after quality not cheap and nasty.
    Cy Chadwick replied 21 years ago 3 Members · 4 Replies
  • Walter Biscardi
    September 22, 2005 at 10:58 pm
    AJA Io. Keep in mind that you cannot have two Video devices connected to FCP at the same time. So if your deck is connected via Firewire and it’s turned on, you must disconnect the Io and vice versa.
    You can also add an internal card like the AJA Kona series or the Aurora Pipe series.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
    G5 Dual 2.0, AJA Kona 2, Medea FCR2X
  • Felix Bueno
    September 22, 2005 at 11:15 pm
    Hi
    I have a Deckling Extreme and it works perfectly. You can monitoring, edit to tape… There are lots of configurations in the SD series (Standard, Pro, Sp and Extreme) This hardware is not very expensive and runs ok.
    Good luck and good choice
    Felix
    FCP 4.5 HD
    Dual G5
    2 GB RAM
    Atto Scsi2 Seagate Array
    DSR 1500P
  • Cy Chadwick
    September 23, 2005 at 2:54 pm
    can i have deck control at the same time as view on the monitor? If not, what do I need to achieve this???
    Cheers and thanks for the help.
  • Cy Chadwick
