Activity Forums Apple Final Cut Pro Legacy want to set capture preset in fcp5.1.1 for speaker on cannot figure out how
  • want to set capture preset in fcp5.1.1 for speaker on cannot figure out how
    Posted by Todd George on June 23, 2006 at 2:48 pm
    Hello all
    using fcp5x on a 1.8 ghz Powerpc g5 Imac I have 1gig of ram and I’m running os 10.4.6 also I am using a jvc SR-VS30U minidv/vhs deck
    I want to set a capture preset that allows me to have the imac speaker on but canot find the check box to do so in older versions of fcp there was an advanced button is that gone or is the option within another section of the presets
    also this deck is fine for log and capture I have full device control and no prolems however when I try to use it with normal editing and print to video fcp doesn’t really seem to see it… I have consulted the decks manual and it state it may not work properly with various sotfware/hardware but it really doesn’t make sense why would I be able to capture with it at all…very strange
    any help any of you can provide would be appreciated
    take care
    Rob Forsythe replied 20 years, 2 months ago 3 Members · 2 Replies
  • Bouncing Account needs new email address
    June 23, 2006 at 8:10 pm
    [Todd George] “using fcp5x on a 1.8 ghz Powerpc g5 Imac I have 1gig of ram and I’m running os 10.4.6 also I am using a jvc SR-VS30U minidv/vhs deck
    I want to set a capture preset that allows me to have the imac speaker on but canot find the check box to do so in older versions of fcp there was an advanced button is that gone or is the option within another section of the presets”
    The audio is, by default, intentionally MUTED to the Mac’s speaker output during Log and Capture.
    So you should normally monitor the audio directly from the camcorder or deck you are using to capture. (It is the preferred method.)
    CAUTION:
    Many people have reported that noise or “pops” appear in the captured clips if the Mac’s internal audio is left on WHILE capturing… so may want to choose “Off During Capture.”
    However, there is a way you can turn ON the Mac’s speaker if you really WANT to:
    In FCP4x and earlier:
    Final Cut Pro (menu) > Audio/Video Settings… > Capture Presets (tab)
    “Duplicate” the Capture Preset you are now using, when the window opens rename it (I added “MacAudioOn” to the file name).
    Click open the “Advanced” button in the Audio section and turn speakers to “ON during Capture.”
    The Mac speakers/audio-out will now play Audio during the preview in the Log and Capture window.
    In FCP5x and later:
    In the Record Tool:
    Clip Settings, near audio buttons, choose: Preview: “ON”
  • Rob Forsythe
    June 23, 2006 at 8:11 pm
    This list contains virtually everything to try to enable:
    a. External Monitor VIDEO and AUDIO via FireWire & DV deck or camcorder.
    b. Viewing in the Canvas window on the computer screen.
    c. Being able to record on the external FW DV deck or camcorder.
    d. Being able to capture from a FW device.
    If working this list doesn’t cure the problem… you may have a serious PROBLEM!
    Try things in this order until you find the “cure”:
    1. Make sure you have only ONE (1) FireWire deck, camcorder, DV capture “card”, or D-to-A converter or video device attached to the computer at a time. Any more than one DV device can cause loss of signal and control.
    2. Make sure you have View (Menu) > External Video> All Frames set.
    (If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
    3. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen or “pushed into” other windows.
    4. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
    5. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
    6. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
    7. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
    8. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
    9. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
    10. Make sure you have chosen FW output for A/V:
    Video Playback: Apple FireWire NTSC (720 x480)
    Audio Playback: FireWire DV
    11. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
    12. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
    13. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
    14. Re-check that your FW cable is well-connected at both ends (or try a new cable).
    15. Important: Quit FCP, then Restart FCP.
    16. Now again, make sure you have View > External Video > ALL FRAMES set…
    If it still does not work. “Trash” the FCP Preferences on the Mac
    “FCP Rescue” is a free Apple Script that will Trash the Preferences.
    It will also restore your user settings afterwards.
    Download:
    https://www.macupdate.com/info.php/id/14729
    If you have “lost” your entire FW connection between the Mac and the device, go HERE:
    https://docs.info.apple.com/article.html?artnum=301852
    >Then, start again at my “step 1” above.
