Activity Forums Zaxwerks Want to import Illustrator film WITH colors!
  • Want to import Illustrator film WITH colors!
    Posted by Clint Wood on December 4, 2006 at 6:04 pm
    I have Zaxwerks ProAnimator. I want to import an Adobe Illustrator file with colors, but even if the box is checked at the import dialog, all I got is an entire blue 3D-object. How can I map the original colors to that object?
    thanks in advance!!
    clintwood
    Clint Wood replied 19 years, 9 months ago 2 Members · 2 Replies
  • Jon Okerstrom
    December 5, 2006 at 2:30 am
    Hi Clintwood.
    Here’s my guess…
    your largest object is blue. your other objects may be other colors, but they’re not visible because they’re all on the same Z plane. Try selecting your other objects and moving them forward in Z space. If you’ve checked the “use Illustrator colors” box, you should get those colors.
    How’s my guess?
    Jon
    One other thought – the “use Illustrator colors” option does not mean you can use fancy blends or patterns. You need solid Illustrator colors.
  • Clint Wood
    December 5, 2006 at 9:13 am
    // How’s my guess? //
    Hi Jon
    there were two problems. The first was, that the illustrator artist grouped everything together, so I couldn’t seperate them in Zaxwerks.
    So I asked him to delete the group now it works – AFTER I moved them forward in Z space 🙂 So you were right, too. Thanks for the hint!
    greez
    clintwood
