Activity Forums Maxon Cinema 4D Want to double the length of project and have all elements group change with it
  • Want to double the length of project and have all elements group change with it
    Posted by Dale Hildebrand on November 18, 2009 at 1:02 pm
    Hi there,
    I have a project that is 630 frames long with over 500 different moving objects. I wish to double the length (1/2 the speed) of the project. So, if I change the project settings maximum time to 1260 frames is there a way to group change all object to stretch in length/time to match 1260 frames as well as all keyframes double in length/time?
    Thank you for any help,
    Dale
    Adam Trachtenberg replied 16 years, 10 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    November 18, 2009 at 2:53 pm
    The easiest way to do it (that I know of) is to make sure that all animated objects are visible in the timeline, then select the Summary track at the top and drag the top bar out to the end of the project. That will scale all of the animation.
