Activity Forums DaVinci Resolve Want to access the Undo History. Read the manual. Here’s the problem…
  • Want to access the Undo History. Read the manual. Here’s the problem…
    Posted by Duke Sweden on October 13, 2017 at 2:31 pm
    Hey Tero, I did what you always say, I read the manual. Did a search for how to access the history of changes, like you can in Premiere Pro or Photoshop. This is what it says:
    To undo and redo using the Undo List:
    1. Choose edit>undo list
    2. When the History dialog appears, click an item on the list to undo back to that point.
    Now, here is my conundrum. There is NO “undo list” under “Edit”. Only Undo, Redo, and Undo History which is grayed out. I’m sure you’re going to tell me how to ungray History (Yeah, you can only access it in “Edit”, I want this feature in the color page), but the fact remains that the manual tells me to click something that doesn’t exist. This is the pdf manual that came with v. 14 so it’s not like I’m looking at an outdated manual.
    Redeem thyself, Ahlfors!
    Dell XPS 8920
    Intel i7 core 7700 build
    GeForce GTX 1050ti
    32 Gigs of RAM
    3 7200 RPM SATA Drives
    Windows 10 64-bit
    Premiere Pro CC 2017 v.11.0
    Glenn Sakatch replied 8 years, 9 months ago 3 Members · 5 Replies
  • Tero Ahlfors
    October 13, 2017 at 2:53 pm
    Short answer: There’s no undo history for the color page because,
    Long answer: Page 691 in the Resolve 14 manual (September 2017).
  • Duke Sweden
    October 13, 2017 at 8:45 pm
    You know, you really should learn how to do these things yourself rather than depend on the manual to bail you out! 😉
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Tero Ahlfors
    October 14, 2017 at 6:52 am
    Straight up: I didn’t know why and was not expecting to actually get an answer for that… But there it was.
  • Duke Sweden
    October 14, 2017 at 11:52 am
    And just when I thought nodes were confusing 😉
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Glenn Sakatch
    October 14, 2017 at 4:39 pm
    I’m assuming your answer is because each node has its own set of undo commands?
    Glenn
