Activity Forums Apple Final Cut Pro Legacy Waht is the correct workflow for downconvertin 24P HD to DVcam 29.97
  • Waht is the correct workflow for downconvertin 24P HD to DVcam 29.97
    Posted by Xelvin on January 9, 2006 at 11:21 am
    Greetings!
    I hope I make myself clear as to what my question is 🙂
    I have been through the process before, but it’s been a while.
    I have footage shot on a Sony F900 and want to have it downconverted to DvCam.
    Capture it with FinalCut 5.0.4—Edit it and ultimately have it onlined on HD.
    Questions:
    1. Any particular instructions on having the footage downconverted?
    (last time I had them place the actual HD 24p windowBurn on the bottom part of the letterbox- Should both Timecodes be sinked up at zero. I know that they will differ eventually but should they start off the same?)
    2. Need FCP settings – After that I’m pretty much lost 🙁 Can’t recall the process from here on)
    I understand that it might e alot of explaining, so If there is a link anyone knows I would greatly apreciate it.
    Xelvin
    Arnie Schlissel replied 20 years, 8 months ago 2 Members · 1 Reply
