Activity Forums Maxon Cinema 4D Vray for C4d 1.9 Camera animation question
  • Vray for C4d 1.9 Camera animation question
    Posted by Paul Rijkaard on June 9, 2016 at 6:41 pm
    Hi all
    I am new to vray and struggling to understand why my render time has gone up 7 times since I baked the GI, is this normal???
    The shot is 1,500 frames. it involves a very slow move into a group of objects in a room. only camera moves.
    I started the scene simply using the GI presets – I chose “01F: special camera IRR+LC” during scene setup the shot was taking approx 8 mins per frame at 1080p. I rendered 60 frames, but there was a slight flicker in the shadow areas.
    I then followed Stefan’s tutorial which may have been based on an earlier version of vray (I am using 1.9)
    https://forum.vrayforc4d.com/index.php?threads/10483/
    This basically says (bake LC and then bake IR and then render)
    I baked the GI, then started to render a few frames, but the render time has now lengthened to 58 mins per frame. I have only rendered a couple of frames so far, I can’t see any flicker, but would need more frames to make a judgement …
    Am I doing something wrong?? why is the render time so massive? I feel like I could render more quickly using 2 passes of brute force (although can’t test it yet as computer is processing the other). Should I try this?
    I understand that I need to be patient when rendering GI, but this seems to go against the argument that Vray is a much quicker physical renderer than … the others.
    Any advice would be gratefully received.
    Paul Rijkaard replied 10 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
