Activity › Forums › Apple Final Cut Pro Legacy › VRAM for Color?
VRAM for Color?
Posted by Samahcinema on August 7, 2007 at 4:20 amI tried to open Color on my PowerPC G5, and it told me that I didn’t have enough VRAM… How is VRAM different from regular RAM? Do you install it in the same slots that that you install regular RAM into? Any feedback would be helpful…
Uli Plank replied 19 years, 1 month ago 3 Members · 7 Replies -
13
August 7, 2007 at 4:46 am[samahcinema] “How is VRAM different from regular RAM?”
VRAM is built onto the video card.
[samahcinema] “Do you install it in the same slots that that you install regular RAM into?”
No, it is built onto the video card.
If you wish to run color on your machine you will need a new video card.
Samahcinema
August 7, 2007 at 4:50 amThanks for your reply… I don’t really know where I would start to look for one, or what criteria I would use to select one… Could you give me any advice on that?
13
August 7, 2007 at 5:00 amVideo cards for color have been talked about quite a bit on here, even h=more so on the Color forum.
Try doing a search.
Uli Plank
August 7, 2007 at 11:19 amOK, the NVidia is not really adapted to Color. Try to get a X800 (be sure it fits your model) if you can
