Activity Forums Compression Techniques VP6 Squeeze makes better video than FlixOn2Vp6 ?
  • VP6 Squeeze makes better video than FlixOn2Vp6 ?
    Posted by Joseph Dezordi on February 27, 2008 at 10:16 am
    I am trying, I guess like every one else to produce the best quality videos for streaming
    I am still also confused about flv / swf …options.
    I restrict my educational videos typically 1 to 5 minutes because of poor quality broad band in australia
    I have been using Flix Pro to generate swf files from high quality uncompressed AVI files. I make the swf files in flix pro to 12fps, as recomended, & select reduce interlace flicker etc.
    Despite using the options Best / for VP6 & maximum detail for Vector settings, I find I still get flash movies that a are bit ‘ blocky’, also there is lots of unsightly horizontal movement artefact, for example when a child moves her head & a balloon horizontally, the image blurs in the horizontal plain .
    When I attempted to create a smilar project in Sorsenson squeeze using the On2 VP6 pluggin option, I obtained what appear to be better quality videos, less blocky & no horizontal artefact. They are a similar size ( 2.4MB)
    I find this confusing given that the VP6 codec is made by On2 who make Flix pro
    Can any one help me to produce good flash movies ? or am I wasting my time, should I be looking at Adobe flash turbo, or Microsoft silverlight ?
    Joseph D
    Daniel Low replied 18 years, 6 months ago 2 Members · 1 Reply
  • Daniel Low
    February 27, 2008 at 4:43 pm
    It’s unlikely that you are using the exact same settings, as both applications don’t have the exact same feature set.
    Bottom line us that Squeeze is a better transcoding application than Flix, although the codec implementation is probably exactly the same.
    Forget Silverlight, if you can’t get Flash to work well at low-bandwidths then you’ll be even worse off with that Windows technology. (IMHO Silverlight is going nowhere).
    There’s no such thing as ‘Flash Turbo’ AFAIK.
