Activity Forums VEGAS Pro VP 11 Velocity Slo mo goes to reverse
  • VP 11 Velocity Slo mo goes to reverse
    Posted by Mike Hinkel on December 25, 2011 at 1:06 am
    I have noticed when wanting to slow the velocity of an event in VP11 that it actually plays the event in reverse at a certain point. What is up with that? Anyone know?
    Mike Hinkel replied 14 years, 8 months ago 2 Members · 2 Replies
  • Mark Barton
    December 25, 2011 at 5:13 am
    This is as designed. The text below is from the online help. Dragging the line all the way down goes to a negative velocity rather than 0.
    Right-click a video event, choose Insert/Remove Envelope from the shortcut menu, and then choose Velocity from the submenu. A velocity envelope is drawn on the event.
    Drag the envelope up to increase the playback speed of the event, or drag down to decrease its speed.
    Setting a velocity envelope to a negative value will cause the event to play in reverse. Video events can only be reversed if there is media to reverse: an event cannot be reversed past the beginning of a media file. An event that has been reversed will play backwards until it gets to the first frame and will then hold that frame for the duration of the event.
  • Mike Hinkel
    December 25, 2011 at 7:41 am
    Thanks Mark. I didn’t realize this was the case. I often forget the online help that is available. Thank you for reminding me. ;^)
