Activity › Forums › Adobe After Effects › volume light in 3d space
  • volume light in 3d space
    Posted by Kayak on September 22, 2007 at 4:49 pm
    hi there,
    is it possible to build volume light in an ae 3d room while the camera is moving behind rows of pillars so sometimes it will shines through.
    also the camera will move around a curve!
    any advice would be nice!
    ciao kay
    Kayak replied 19 years ago 4 Members · 4 Replies
  • Erik Pontius
    September 22, 2007 at 5:21 pm
    Not free, but Trapcode LUX is a great plugin creating for volumetric lighting. You can download the demo and try it out.
    Erik
  • Jerzy Drozda jr
    September 22, 2007 at 9:40 pm
    hey
    you might want to check my tutorial on volumetric lights:
    https://library.creativecow.net/articles/drozda_jerzy/VolumeLight.php
    and also this one:
    https://library.creativecow.net/articles/drozda_jerzy/CEPixelSampler.php
    you can try using them in conjunction to create the effect.
    also you can emulate the Lux plugin by simply creating a
    layer with a circle effect, and then applying CC Fast Radial Blur with a bit of offset from the center of the circle.
    hope that helps a bit.
    maltaannon.com – Free After Effects Video Tutorials and more
  • Mike Clasby
    September 23, 2007 at 2:36 am
    If you aint got the Bucks for Lux, here’s a freebie, but I don’t think I will really do what you want, cutting the beam od light off with Pillars, I too think Maltaannon’s is the best shot, and also Lux doesn’t work on 3D layers as far as I know.
    https://www.petertorpey.com/tutorials/volume_light/
    Click on the link at the bottom of the page, the second to last sentence is the “Download the script” link. Put the .jsx file into the AE Scripts Folder. You add a light of choice (I
  • Kayak
    September 24, 2007 at 6:02 pm
    hi everybody and thank you for the help.
    after a lot of trying i will do something with lux.
    yikesmikes you are right that lux behalfs not as a real 3d layer and shine threw the pillars but i will make a precomp of the pillars and take it to mask out the lux layer.
    i also tried the peter torpey tutorial but since my oriental windows are a lot bigger than the startbeam of the volume light i layed it behind the window in 3d space and it does not worked like i need it, because the lightbeam did not show through the window into the room (maybe my mistake, but i
