Activity Forums Apple Final Cut Pro Legacy Voiceover tool
  • Posted by Steve Knattress on November 20, 2011 at 2:13 pm
    I have a job tomorrow editing a VoiceOver to pictures, on to a show using FCP7, something I have done a lot in the past, but can some one answer this question.
    Tomorrow I think I have 2 commentators, on AVID where I usually do this job I record dual mono, each commentator to their own track (one panned left one right through the mixer, they are on lip mikes so there is little spill) so I can treat
    /edit each one separately ( filters, dynamics, levels etc.)
    (Commentator and colour man require different treatments)
    Is there away to record 2 separate voice over tracks (stereo pair) into FCP7 like you CAN on AVID MC?
    Or do I need to premix/treat the mikes in an external mixer prior to import both to a mono track?
    I have had a play today on my system and cannot see away.
    Also it seems that with FCP7 and OS10.7.2 the voiceover tool crashes FCP if I select other than 44.1Khz audio for the VO tool, any one else seen this?
    Hopefully the clients Mac will have SL!
    Steve Knattress replied 14 years, 9 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    November 20, 2011 at 3:00 pm
    When recording, the Voice Over tool works with the Sound Manager to record in mono mode. When you choose the audio interface input for a stereo input device, the Voice Over tool uses only the left input channel (channel 1) of a stereo input device when recording; the right channel is ignored.
    So you’ll need to mix the audio before the input if you use the VO tool.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Steve Knattress
    November 20, 2011 at 4:46 pm
    Thanks for your quick reply,
    just what I thought, looks as if AVID wins again 😉
    Steve
