Activity Forums VEGAS Pro voice over track covers another track?
  • voice over track covers another track?
    Posted by Hans Castrop on December 18, 2012 at 3:05 pm
    I added an audio track and put my mono voice over file in it. When I move the audio wave in the track, another copy of the file shows underneath. Why is that? How do I get rid of this and why is it there in the first place? I noticed it only happens when I cut the audio and move it a bit. Then the underlying file is uncovered. Not when I move an uncut file. I cut by using “s” on the file.
    Hans Castrop replied 13 years, 9 months ago 2 Members · 4 Replies
  • John Rofrano
    December 18, 2012 at 5:45 pm
    [Hans Castrop] “When I move the audio wave in the track, another copy of the file shows underneath. Why is that? “
    You must have added it twice by accident. Maybe you recorded twice from the same location?
    [Hans Castrop] “How do I get rid of this and why is it there in the first place? “
    Select it and press the Delete key.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Hans Castrop
    December 19, 2012 at 9:40 am
    Hi
    well, I’ve tried to repeat the problem, but after a restart I can’t anymore. So I guess deleting the double files in the track and move on is the only thing left. I still can’t believe it was me copying files though. I had 10 audio files of which I cut 5 with “split events at cursor” and when I moved those files they had duplicates underneath and definitely the uncut files didn’t. I guess the restart of the PC has moved the bits and bites in place again.
    awell, time to move on and thank you for your reply John.
    HC
  • John Rofrano
    December 19, 2012 at 1:51 pm
    [Hans Castrop] “I still can’t believe it was me copying files though. “
    All you need to do is accidentally hold down the Ctrl key while moving an event and you have unknowingly made a copy without wanting to; so it’s easy to do.
    ~jr
  • Hans Castrop
    December 19, 2012 at 4:23 pm
    much too easy,
    many thanks.
    HC
