Activity Forums Audio Voice-over: conventions of the genre
  • Voice-over: conventions of the genre
    Posted by Tony Ostrovsky on October 25, 2009 at 10:49 am
    Hello,
    I have recently taken a role of a sound engineer in a voice-over recording studio. Quite a big number of demo recordings has been done already, so now I’ll have to process them, if necessary.
    From what I’ve read in other posts, I presume the following techniques might help:
    1) If the dynamic range is too high (for reasons other than creative – an artist often moves away from the mic), apply subtle compression – never more than 6 dB.
    2)Normalize.
    3)When applicable, enhance and over-compress (stereotypical commercial sounding)
    4)If the proximity effect had not been creatively used, try to get rid of it with EQ’s (no bassy sounding).
    5)Get rid of over-emphasized ‘S’ and pops.
    6)EQ tonal imperfections caused by mic placement/room.
    Is there anything else I should do? Is there something I certainly shouldn’t do?
    Thank you!
    Anton
    Jordan Wolf replied 16 years, 10 months ago 3 Members · 5 Replies
  • Peter Groom
    October 25, 2009 at 1:24 pm
    HI
    Im sure every csutomers requirements may be different, but if youre
    1) talking about taking these recordings and using them as a broadacst product, then yes some but not all of the list will apply. Def not normalise if youre going to braodcast it. Youll have to submit to braodvasters at the right level and this is not normalised.
    2) If youre recording and then handing them on toa customer, I d find out what they want as it will differ every time.
    3) If youre suppplying to a studio to build into a commercial or programme, then NONe of your list.
    I wouldnt thank you for doing anything to a recording (not even applying eq at the mic) unless it was chronically bad, and even then id expect this to be fixed before recording anything. Same goes for the artist drifting off mic! Do it again if its audible.
    No eq, no compression , no normalizing. Just record well. Ill process as applicable in the final mixdown.
    Peter
  • Tony Ostrovsky
    October 25, 2009 at 1:31 pm
    Thanks a lot for a detailed answer Peter!
  • Jordan Wolf
    October 26, 2009 at 4:15 am
    If you can apply dynamic compression and/or equalization, I would do so. Maybe put in a request for a BSS DPR 901II? That will give you a whole new dimension of control that you didn’t have before – and will open your eyes (and ears) to more possibilities.
    Wolf
  • Tony Ostrovsky
    October 26, 2009 at 10:48 am
    Thanks for the hint – the device looks amazing!
  • Jordan Wolf
    October 26, 2009 at 3:42 pm
    Yeah, basically, it’s a 4-channel compressor with a permanent sidechain EQ attached. Excellent for keeping sibilance and proximity effect at bay.
    Wolf
