Activity › Forums › Apple Final Cut Pro Legacy › VO Tool in FCP and APOGEE Duet – only one Input Channel?
  • VO Tool in FCP and APOGEE Duet – only one Input Channel?
    Posted by Dean Neal on November 6, 2010 at 6:40 am
    I would love some advice on this one…
    I am setting up an ability to commentate (Voice Over) motorsport vision remotely (to avoid travel to the main production house) at home.
    Now, I have two headsets with XLR inputs and immediately liked the look of the Apogee DUET as a great quality Audio Interface.
    Because there are TWO of us commentating the vision, this looked to be the perfect fit.
    I have set it up and I can see in the Apogee Maestro mixer software, it can see both Mic 1 & 2 inputs and I get a nice monitored signal back into my headphones.
    THE PROBLEM IS HOWEVER:
    When I use FCP’s VO tool, it only pics up MIC1!!
    Surely there is a way for both inputs to be recorded into FCP?
    I tested in Garageband and it sees and records both fine.
    So my question is what’s the best option here?
    I don’t think a XLR Y cable will cut it as I need to manage each commentator’s level separately.
    So, the only other way I can deal with this is a small Mixer on the two Microphone inputs, that then are connected to the single Mic1 input on the Apogee? That really annoys me, a production software package with Apple Core Audio support should be able to handle TWO inputs for VO work!
    I can’t see how Soundtrack Pro will work either, as we need to see the vision as we commentate over it.
    Please let me know what you guys suggest.
    Dean…
    Dean Neal…
    Dean Neal replied 15 years, 10 months ago 3 Members · 6 Replies
  • Jerry Hofmann
    November 6, 2010 at 4:16 pm
    I think you need to combine the two outputs from the Apogee with a combiner cable… There’s one that will end up being a stereo mini I’d think, and then you’d plug that into the mic input on the Mac. If that fails, you could combine the two mic’s with a mixer for a mono out.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Dean Neal
    November 7, 2010 at 4:04 am
    Thanks for the reply Jerry.
    I can’t see how a combiner cable would work as it’s a Firewire interface to the MBP.
    That’s the bottom line with my frustrations – it should be able to combine via Software!
    The Apogee software in OSX is great… it’s crazy for this to not be able to handle two-inputs into the VO Tool. Ugh.
    The Apogee is such a beautiful bit of hardware, I get annoyed thinking I have to find something external to combine audio.
    I guess I have to look at a Mixer as you say… or can anyone give me sage but simple advice on how to commentate over vision using Soundtrack Pro for VO purposes?
    Also – any recommendations on a nice, simple (cheap) mixer that would work well into one of Apogee’s XLR Mic Inputs?
    Dean…
    Dean Neal…
  • Andy Mees
    November 7, 2010 at 10:12 am
    Hi Dean
    That’s correct. Final Cut Pro’s Voice Over Tool is by design only a single channel recording device. From the manual:
    “When recording, the Voice Over tool works with the Sound Manager to record in mono mode. When you choose the audio interface input for a stereo input device, the Voice Over tool uses only the left input channel (channel 1) of a stereo input device when recording; the right channel is ignored.”
    Nope, not as separate channels .. at least not using the VO Tool … you could record both channels using Log and Capture but then you would not get the simultaneous timeline audio/video playback. But if you’re willing to combine the two audio inputs and record them via the VO Tool as a single channel then you might want to have a look and see if your Apogee Maestro software can combine the two channels … at the very least I would expect you could take a center panned output from the device’s headphone out and run that into your Mac’s Line In (Built-in Input). Not a perfect solution but it may work nonetheless.
    Hope it helps
    Andy
  • Dean Neal
    November 7, 2010 at 12:48 pm
    Thanks for all the replies guys…
    Andy – I like your lateral thinking, but I just can’t justify in my mind using a $700 (AUD) Device that has beautiful Mic Pre-Amps… Core Apple Audio Support and then using the headphone outs…
    I guess I either trust Garageband for VO creation or SoundTrack Pro (even though I have hardly used it before)…
    The best option for me I think is buying a simple Microphone Mixer that I can XLR Mono Output to the Duet… Any suggestions on which one to get?
    Dean…
    Dean Neal…
  • Andy Mees
    November 8, 2010 at 4:23 am
    Hi Dean
    Our boys in the field use 3 channel Shure FP33 mixers (overkill for what you need) … a Glensound GS-CU005 would be more suitable for you but they’re a UK based company and I don’t know price or availability details for that one.
    But before you take out a second mortgage, perhaps a simple Y split cable solution (usually for splitting a single channel rather than joining two disparate ones) is worth a try :
    https://www.seismicaudiospeakers.com/Set-of-2-XLR-Y-Cables-p/2-xlry.htm
    Hope it helps
    Andy
  • Dean Neal
    November 8, 2010 at 12:44 pm
    Thanks again Andy for getting back to us with some great ideas…
    The other guy who does VO with me is softer so it would be a real pain to have to adjust levels like mad in POST (Software).
    I ended buying a simple 10-track Xenyx 1002 mixer, using a mono XLR Send to the Apogee. Sounds great and clean thankfully and I can ride levels fine.
    A bit of overkill agreed and I hope Apple get the FCP VO Tool to support multiple inputs in future. Just silly the way it is now.
    Dean Neal…
