Activity › Forums › Square Box CatDV › Visual access to Server Admin panel for simplified Read Only clients
  • Visual access to Server Admin panel for simplified Read Only clients
    Posted by Scott Goddard on May 16, 2013 at 9:52 pm
    Is it intended that typical ‘read only’ users should have access to visually see the Status / Admin panel? Maybe I am missing something here?
    I would like the read only clients to have as simplified an experience as possible and even for the more curious users I certainly would not want them to have access to see the information in the Server Admin Panel. Information such as which users have have access to which groups is quite private, especially in a large org. The connections tab also gives away a wealth of information.
    Is there a way to disable visual access to these windows?
    Perhaps it is intended that we are to buy the web clients to have the ‘simplified’ front end?
    Scott Goddard
    Neo Verite Limited
    http://www.neoverite.com
    Scott Goddard replied 13 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
