Activity Forums Adobe After Effects Expressions Visible line break characters in text string
  • Visible line break characters in text string
    Posted by Mikael Holmström on February 6, 2018 at 12:17 pm
    Hi all,
    In short:
    Is there a way to tell a text layer to write the sourceText with visible special characters (\r or \n for example)?
    The longer version:
    I’m building an essential graphics template for Premiere where calculations are made depending on the number of lines / line breaks in the essential graphics input fields for a text layer. All works fine in AE, but when using the template i Premiere some miscalculations occurs. I would think it has to do with hidden characters, probably line break characters, that messes things up.
    I need do debug this some way, and since I can’t cut & copy the text from Premiere into a text editor, I would like to add a “debug text layer” in the AE comp/template, with visible special characters. This is why I need a text layer that write the sourceText with visible special characters.
    Thank you!
    Mikael
    Mikael Holmström replied 8 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
