Activity Forums Adobe After Effects Visible area of mask renders transparent
  • Visible area of mask renders transparent
    Posted by Adam Watson on May 26, 2013 at 12:49 am
    Hello, I’m trying to extend the surface of a whiteboard so you don’t see the edge by adding a plate of the whiteboard beyond the edge and then using a mask to blend them together. It looks fantastic in the preview window, but when I render it out, the edge is still barely visible, like the opacity was set to something other than 100%. I tried using mask add, subtract, the plate as top layer, the plate as bottom layer, making sure feathering isn’t affecting it. Rendering in 16 bit just in case. Nothing will make it be solid when it renders.
    John Cuevas replied 13 years, 3 months ago 2 Members · 1 Reply
  • John Cuevas
    May 26, 2013 at 1:16 pm
    Can you post a screen grab of the rendered plate
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
