Activity Forums Adobe Photoshop virtual memory in C2
  • virtual memory in C2
    Posted by Rick Kz on August 14, 2007 at 9:24 pm
    the cpu is a HP8400 w/4Gb ram and winXP (32bit so only 3Gb ram)- 5 internal SATA drives are installed for 1.3TB of storage- the files are not that large but can get up 1GB-
    currently C2 will freeze or hang minutes after a hour or so of work with multiple files-
    what would be the best recommended virtual memory settings for C2 to keep stable application performance
    how about the boot.ini file? suggested mod?
    thanks very much in advance
    Rick Kz replied 19 years, 1 month ago 1 Member · 1 Reply
  • Rick Kz
    August 14, 2007 at 11:47 pm
    with so many options available, can anyone recommend the best boot.ini 3Gb switch options to utilize the 4Gb of installed ram in this 32bit winXP cpu?
    again, many thanks in advance
