Activity Forums VEGAS Pro Virtual Dub to Sony Vegas Compression
  • Virtual Dub to Sony Vegas Compression
    Posted by Keyser Chapton on February 13, 2017 at 6:51 pm
    Hi guys, just a small question.
    I record with Dxtory Magic YUV 4:2:0 for youtube gaming videos.
    I can set the timescale to 10% in a game, so it plays 10% slower. I record with 60fps, then I want to speed it up 10x, so I get 600fps.
    I want to speed it up using Virtual Dub. I set the frame rate in Virtual Dub to 600. But I dont know what compression to use…
    Should I use “uncompressed” or “magic yuv 4:2:0” as compression? When I use magic yuv 4:2:0 will it compress my video twice?
    for example, I already have Magic YUV 4:2:0 in Dxtory, now I use it again in Virtual dub, so it means that it will compress it twice?
    Keyser Chapton replied 9 years, 6 months ago 1 Member · 1 Reply
  • Keyser Chapton
    February 13, 2017 at 6:58 pm
    I rendered both versions now with virtual dub.
    I simply dont really understand.
    the source file has 6,5gb.
    The uncompressed method has 35gb.
    The magic yuv method has 6,4gb (nearly the same as source file).
    But which method has better quality for sony vegas?
