Activity Forums Apple Final Cut Pro Legacy Virtual Clips in FCP4.5?
  • Virtual Clips in FCP4.5?
    Posted by Freefilms on July 28, 2006 at 9:36 am
    when i used to work in premiere, i could make a virtual clip out of an edited sequence of clips. i’d then be able to apply motion effects to that virtual clip for picture-in-picture & split screen stuff. it saved a lot of time.
    i’m sure fcp has this capacity. i’m just not sure where to start. any help would be much appreciated. many thanks in advance.
    Freefilms replied 20 years, 2 months ago 2 Members · 2 Replies
  • Tom Meegan
    July 28, 2006 at 10:34 am
    It is called nesting in FCP.
    Highlight the section of the timeline you want to nest.
    Option-C. Or Sequence > Nest Item(s)…
    It will ask you to name the nest. This will show up as a sequence in your browser (so you can edit the contents of the nest.)
    If you want to apply filters or modify the motion parameters of a nest, Option double click it to load it into the Viewer. The regular double click you would use to load a clip into the viewer, loads the nest as a sequence into the timelime when you double click a nest.
    Tom
  • Freefilms
    July 28, 2006 at 11:14 am
    thankyou for your prompt reply tom. i really appreciate your help. i’m staying up late tonight & i look forward to putting your ideas into action.
