Activity Forums Maxon Cinema 4D Viewport Back-Image Problem
  • Sean Jenkinson
    June 30, 2022 at 9:48 am
    Here’s something else weird I just discovered.
    If I go into 4 view mode I can upload separate images into separate views. I can then hover my cursor over a view and maximise it and it retains its bg image. I can then go back to 4 view mode and hover over a different view and maximise that and still see the correct image.
    If I stay in maximised mode and change views, however, the bg image will not change to the correct image uploaded for the new viewport. Does that ring any bells?
    It means I can continue for the time being but its not really a solution… and pretty bad for efficient workflow.
  • Sean Jenkinson
    June 30, 2022 at 3:18 pm
    If you’re interested… I contacted Maxon support. They recommended I open the preferences folder and delete the Maxon C4D R25 user folder, which I did.
    I’ll have to re-establish all my prefs etc, but the problem is now definitely resolved.
Page 2 of 2
