Activity › Forums › Avid Media Composer › Viewing TC in timeline?
Posted by Scott Davis on November 3, 2007 at 12:46 amIs there a way in the Symphony to view the sequence TC? Other than the TC window tool?
Jon Zanone replied 18 years, 10 months ago 3 Members · 2 Replies -
Carl Amoscato
November 3, 2007 at 8:17 pmHi,
You should be able to see the sequence timecode above the composer window (the right side monitor).
good luck,
Carl -
Jon Zanone
November 5, 2007 at 11:57 amYou may also have to change the default view (I believe its frames). As Carl said, click on the numbers centered above the source and record monitors. Select ‘source>V1>TC’. You can do that for both monitors. In AXP, you can only see one view at a time (master, In/Out, Duration), but in MC, you can select several…
Jon
“So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
Del Amitri – “Make it Better”
