Activity Forums Avid Media Composer Viewing Project on external monitor through MOJO
  • Viewing Project on external monitor through MOJO
    Posted by Mike Salerno on July 27, 2006 at 9:58 pm
    Hello All,
    I’ve got an Ikegami 9′ inch broadcast monitor has has BNC Video Inputs, the monitor, unfortunately does not have an S-Video input.
    I have been going out of the AVID MOJO with composite cables and into the broadcast monitor with the BNC’s. I am getting an “Out of Range” error and I cannot view my footage through the monitor. Any ideas why this is happening?
    Also, there have been times where the “DV OUTPUT SETTING” under settings is greyed out and I cannot select anything..any ideas why I cannot select?
    You guys have been really helpful and knowledgeable, I appreciate it!
    – Mike
    Martin Kraut replied 20 years, 1 month ago 2 Members · 1 Reply
  • Martin Kraut
    July 28, 2006 at 8:22 am
    You have to use Composite in the Video Output tool within the Avid Software.Also check your deck preferences.If these settings are blank,add a new Firewire – channel for the Avid DNA.
    The Avid Software must be configured correctly to communicate with the Mojo Box
