Activity Forums VEGAS Pro Viewing Preview with tight lip sync
  • Viewing Preview with tight lip sync
    Posted by Prolog on April 6, 2007 at 3:05 pm
    I’m having problems viewing picture and audio in sync. In the trimmer, sync is good and clear. Playing from the timeline, sync floats and pix is soft. I’m using a Dell duo core with 2 gb RAM, but no external audio card. Seems like enough horsepower, but I’m wondering if exteral card like Matrox RTX-100 would let me watch in sync with clear pix. Anyone usiing the RTX 100? Or should I get the full-blown Decklink? I shot HDV, but captured DV. Thanks for any advice in tweaking my system so I’m not always worried about sync drifting.
    Jerry Waters replied 19 years, 5 months ago 4 Members · 3 Replies
  • Gary Kleiner
    April 6, 2007 at 4:11 pm
    What preview mode are you set to?
    Also, do you have a second computer monitor hooked up? If so, use it with preview out to secondary monitor.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Charles Avanti
    April 6, 2007 at 4:18 pm
    If it plays fine from the trimmer, and you have not shifted it on the timeline, you don’t have a problem. For your audio sync adjustment go to: Options–>Preferences–>Preview device. Adjust the sync offset.
    As for not clear video; in video preview window (alt=4, click for external monitor and try “best full”.
    Charlie
  • Jerry Waters
    April 6, 2007 at 6:17 pm
    Set your preview on “Preview-quarter”. It should be in sync but blurry perhaps. If you still have to test your sync on the timeline, do a small region and go to “Tools-Build Dynamic Ram preview” and the region will play as rendered, even if the video resolution is set to higher level.
    JerryW
