Activity Forums Adobe After Effects Viewing Other Layers While Working with A Mask
  • Viewing Other Layers While Working with A Mask
    Posted by Sdelahoyde on November 30, 2006 at 5:55 pm
    I’m trying to build a little project with a stroke line going through a series of solids, like a slalom. Looking at it from Top perspective and have everything built just fine. Only problem, and I can’t for the life of me figure out how to do it, even though I’m sure it’s just a toggle somewhere, is how to view those solid layers whenever I start working with the mask/path. Whenever you touch the mask to alter it, the layers below disappear. So I can build the thing, sure, but that means having to tweak the mask, go back and look where it is in relation to the solids, alter it a bit, ad naseum. There has to be a way to tell AE to just leave all the layers visible when working with masks and looking from above.
    Steve
    Mylenium replied 19 years, 10 months ago 2 Members · 1 Reply
  • Mylenium
    November 30, 2006 at 7:41 pm
    Switch from OpenGL to Adaptive Resolution and make sure you set the Adaptive resolution reduction in your preferences to something you deem acceptable.
    Mylenium
    [Pour Myl
