Activity Forums Adobe After Effects Viewing one Comp while editing another
  • Viewing one Comp while editing another
    Posted by Charles Taylor on April 5, 2010 at 4:15 am
    Hi there,
    Long time Shake user who is using AE for one project – Trapcode Particular turns out to be the right tool for the job, and there’s no Shake version…
    In Shake, I will often have one node loaded into the viewer while I edit another node. In After Effects, I have some nested compositions. I would like to view the topmost comp while editing layers inside one of the inner comps. How do I do this?
    Thanks in advance.
    Roland R. kahlenberg replied 16 years, 4 months ago 3 Members · 3 Replies
  • Roland R. kahlenberg
    April 5, 2010 at 4:41 am
    IOW, you want to have two Comp Panels open and one Timeline panel.
    At the top left of your current Comp Panel is an arrohead that acts as a drop-down menu. Choose Open New Viewer. You’ll now have two comps open. You’ll need to drag one of the two panels away from the frame so that it sits on its own frame. Check AE’s Help on setting up Workspaces to get an idea how to perform this task.
    You’ll also need to lock each comp panel – the lock icon is towards the fra left of a comp panel.
    HTH
    RoRK
    Sell your AEPs with broadcastGEMs’ DVD series of templates. Click here for more
  • Todd Kopriva
    April 5, 2010 at 7:51 am
    See “Edit this, look at that (ETLAT) and locked Composition viewers”. This page contains, among other things, this handy nugget:
    “To lock the current viewer, split the current frame, and create a new viewer of the same type in the new frame, press Ctrl+Alt+Shift+N (Windows) or Command+Option+Shift+N (Mac OS).”
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
    April 5, 2010 at 8:30 am
    [Todd Kopriva] “”To lock the current viewer, split the current frame, and create a new viewer of the same type in the new frame, press Ctrl+Alt+Shift+N (Windows) or Command+Option+Shift+N (Mac OS).””
    Sexay!!
