viewing images on timeline?
Posted by Val Reynolds on December 1, 2009 at 3:19 amI can not see my timeline video images and do not know what I did to change my Vegas 8 setup. When I put a file on the timeline, I can preview it – but can not see what it is when it sits on timeline.
Any ideas?
Theo Van laar replied 16 years, 10 months ago 4 Members · 14 Replies -
Theo Van laar
December 1, 2009 at 7:48 amJust press Ctrl + Shift + I to see the active take information.
And go to OPTIONS-PREFERENCES-tab VIDEO to set the display of thumbnails (choose between NONE, HEAD, TAIL etc.)
Theo
Val Reynolds
December 1, 2009 at 4:00 pmThanks – I know see the text name on top of my timeline video clips but still can not see the video image of what each clip is. I could not find the option you referenced under the “preferences” section tab on video. I am using Vegas Pro8
Theo Van laar
December 1, 2009 at 5:23 pmIn the OPTIONS-PREFERENCES-tab VIDEO in Vegas 8 Pro there is the option THUMBNAILS TO SHOW IN VIDEO EVENTS. This one allows you to choose between NONE, HEAD, HEAD/TAIL, HEAD?CENTER?TAIL and ALL. Unfortunately I am not at home now, otherwise I could have showed a screenshot of this option.
Theo
Val Reynolds
December 1, 2009 at 5:59 pmI can not find this option and have looked at everything under this tab in preferences. A screen shot would help if you can assist!
Val Reynolds
December 1, 2009 at 6:53 pmthis option does not exist on my video tab under preferences.
I am running Vegas Pro 8 (build 144) -
Theo Van laar
December 1, 2009 at 8:10 pmI would just download the latest version of Vegas 8 Pro (which is 8c, unless you are working on a 64bits machine, then its 8.1) and re-install.
https://www.sonycreativesoftware.com/download/updates
Theo
Mike Kujbida
December 1, 2009 at 8:51 pm[val reynolds] “I am running Vegas Pro 8 (build 144)”
Are you 100% certain you’re running Vegas Pro 8 and not one of the Movie Studio versions?
I’m asking because my machine (Pro 8.0c) is at build 260). -
Theo Van laar
December 2, 2009 at 12:43 amMike, you could be very well right that Val is working with Movie Studio. Movie Studio doesn’t have the THUMBNAILS TO SHOW IN VIDEO EVENTS option. In that case the solution is very simpel to get the thumbnails back onto the events: Ctrl + Shift + W (this will also work in Vegas Pro).
Theo
