Activity Forums Apple Final Cut Pro Legacy Viewing HDV on external monitor while editing
  • Viewing HDV on external monitor while editing
    Posted by Mark Wunsch on December 30, 2005 at 8:21 pm
    I try to find the right setting to view HDV material from the timeline on an external video monitor, connected to my HVR-M10E deck. It works in DV mode but not in HDV.
    Any ideas about the settings?
    Cheers
    Mark
    Pfrederick replied 20 years, 8 months ago 3 Members · 2 Replies
  • Shane Ross
    December 30, 2005 at 9:58 pm
    #25 HDV external Monitor Viewing
    Shane’s Stock Answer #25 – HDV external Monitor Viewing
    To view HDV on an external monitor you are going to need to purchase a capture card, like the ones Decklink or AJA offer. They will both play out HDV in real time. The catch is that you cannot view this on a regular TV or NTSC monitor. Since this is HD, an HD monitor will be needed.
    HDV cannot be played out of FCP via Firewire because it’s Long GOP structure is too taxing on your processors to spare the system resources needed to drive an external monitor.
    Shane
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Pfrederick
    January 1, 2006 at 11:01 pm
    Actually I have the Kona LH card and I can send a downconverted SD signal, anamorphic or 4×3 LTBX, to an SD monitor. I highly recomend the Kona LH card. It works great with HDV.
