Activity › Forums › Adobe After Effects › viewing from AE
  • viewing from AE
    Posted by Paul Nevison on November 21, 2006 at 6:50 pm
    hey just new to AE,
    how can i get the compostion window to display at full rez? i have toggled what seems like a quality drop down menu on the composition window but even at full – the picture looks pixelated. also looks bad on my broadcast monitor
    any tips thanks
    G5 DP 2.0 (Power PC)
    4.0G RAM
    OS 10.4.8
    QT 7.1.3
    FCP 5.1.2
    BMD Decklink Extreme 5.7.2
    PAL Land
    Paul Nevison replied 19 years, 10 months ago 2 Members · 4 Replies
  • Michael Duff
    November 21, 2006 at 9:56 pm
    hmmmm – what composition settings are you using? what is the source? graphics/DV/3D?
    There is a Pixel Aspect Ratio Corrector for the composition window so that your canvas doesn’t look squished, this will reduce the quality. But shouldn’t effect the output monitor.
    oh, also make sure your layers are set to best quality by clicking the little check box next to layer name that has a diagonal line in it. A staircase line is draft quality while the smooth line represents best quality.
  • Paul Nevison
    November 22, 2006 at 8:13 pm
    hey duff
    i checked the quality checkbox and they are all set to full quality…..hmmmmm this is confusing.
    4.0G RAM
    OS 10.4.8
    QT 7.1.3
    FCP 5.1.2
    PAL Land
  • Michael Duff
    November 23, 2006 at 6:54 am
    is it video source? or graphics made in AE?
    if it’s video can you look at a quicktime outside of AE and see if it’s pixellated there?
    did you find the Pixel Aspect Ratio correction switch?
  • Paul Nevison
    November 23, 2006 at 11:28 am
    hey mate
    yeah i knew about the pixel aspect switch….what is pixelated is any text and particles from trapcodes particular….basically any graphics made from within AE look bad….and look bad on my external monitor.
    im a complete AE dunce so it could be something simple…just feeling my way with this software
    4.0G RAM
    OS 10.4.8
    QT 7.1.3
    FCP 5.1.2
    PAL Land
