Activity Forums Apple Final Cut Pro Legacy Viewing files with timecode
  • Viewing files with timecode
    Posted by John Mcrae on July 1, 2010 at 2:08 am
    Hi
    I’m new to FCP. I have inherited a project shot with a pmw ex3 and all the files are loaded into fcp and wiped from the cards. I’d like to provide the unedited footage to the client with original timecode. Ideally I want to just provide the files in some form where she can view on her pc but I doubt this is possible. If it can be achieved what software/codecs would she require? What would I need to do to make the timecode visible?
    Alternatively do I just have to print out to tape ( with the original timecode viewable.) Again what would I have to do to achieve that?
    Shane Ross replied 16 years, 2 months ago 2 Members · 3 Replies
  • Shane Ross
    July 1, 2010 at 3:32 am
    [John McRae] ” Ideally I want to just provide the files in some form where she can view on her pc but I doubt this is possible. If it can be achieved what software/codecs would she require?”
    Very possible. Use Compressor and use a QT 6 or 7 setting. PCs have QT. This will encode to H.264. In the INSPECTOR there is a setting for TIMECODE. Turn that on, change the color and size and position and then compress.
    Shane
  • John Mcrae
    July 1, 2010 at 10:50 pm
    Thanks Shane.
    Easy to follow. The clip has timecode displayed.
    Is there any way of displaying the ORIGINAL timecode? I am currently reading new code beginning 00.00 at atart of clip
  • Shane Ross
    July 2, 2010 at 12:25 am
    If you use the TIMECODE READER, then it will read the orginal TC…source TC.
    Shane
