Activity Forums Adobe Premiere Pro Viewing Closed Captions with BMD Decklink Card
  • Viewing Closed Captions with BMD Decklink Card
    Posted by Michael Sacci on March 14, 2018 at 4:21 pm
    I would love if someone can confirm that the Decklink Card can push CC to an external monitor via SDI. This is a proofing system. I’m using PP 2018 on a tower Mac Pro with El Cap OS. Files will already have embedded CC or Ibring in MCC files. I have a JVC monitor that does display CC on both HD and SD signals. I’m not capturing from tape or recording back to tape, just viewing so I would like to spend as little as needed.
    If someone is doing this successfully I would like to know.
    Thanks.
    Brent Marginet replied 8 years, 5 months ago 2 Members · 1 Reply
  • Brent Marginet
    March 14, 2018 at 8:19 pm
    As far as I know and have found most of the BM Hardware does not output the embedded Ancillary Data in an HDSDI Signal.
    I also believe that Avid is the only software that will, either with the Nitris DX or the BM Artist DNxI/O.
    \”MY MEDIA/PROJECT MOTTO: If you think three copies of your Media or Projects are enough. Take a moment to place a value on them and then maybe add two more. Hard Drives are now stupidly cheap. A RE-SHOOT AND YOUR TIME AREN\’T.\”
