Activity Forums Blackmagic Design Viewing both fields with fcpx
  • Viewing both fields with fcpx
    Posted by Bdeleon on April 25, 2013 at 8:49 am
    I can see both fields in my viewer, when I play or when I pause in fcpx,
    I see both fields when I play, but only one when I pause on my video monitor.
    In fcp7 everything works fine,
    I am on 10.8.2 with a Decklink 4k, driver 9.7
    Thank you in advance
    Boris
    Bdeleon replied 13 years, 4 months ago 2 Members · 2 Replies
  • Chuck Pelini
    April 29, 2013 at 7:27 pm
    Top right corner of the viewer window has a switch that drops down. “Show Both Fields” is in there.
  • Bdeleon
    May 2, 2013 at 9:41 am
    Yes I know it is there, and I can see both fields in the viewer.
    I have also removed the check box field jitter in the blackmagic system preferences.
    When using FCP7, I get both fields on a stop frame, in the viewer and on my video monitor,
    When using FCPX, I get both fields on a stop frame, in the viewer but not on my video monitor
    Sorry if I wasn’t clear
    Thank you for the reply
