Activity Forums Apple Final Cut Pro Legacy viewer window is white
  • viewer window is white
    Posted by Robert Schmidtbauer on January 11, 2012 at 10:30 pm
    I have had this problem before and can’t remember what I did to fix it! UGH! the viewer window is all white and whenever I put something into it, it won’t show unless you play it, so when I put a jpeg or still in it I can’t see it…I am sure it is some setting I have wrong, can anyone help or understand my babbling?
    Robert Schmidtbauer replied 14 years, 8 months ago 2 Members · 2 Replies
  • Shane Ross
    January 11, 2012 at 10:40 pm
    #15 White or Black Canvas or Viewer
    Shane’s Stock Answer #15: White or Black Canvas or Viewer
    Make sure the canvas or viewer are selected then go to VIEW>CHANNELS and set it to RGB. It might be set to ALPHA.
    OR…
    Click on the drop down menu above the Viewer or Canvas and make sure that you are on IMAGE or IMAGE + WIREFRAME.
    Shane
    Little Frog Post
  • Robert Schmidtbauer
    January 11, 2012 at 10:43 pm
    Thanks Shane, the channels thing was it…Have a great day
