Activity Forums Apple Final Cut Pro Legacy viewer-timeline luma shift
  • viewer-timeline luma shift
    Posted by Chemix Ferreiro on March 31, 2009 at 6:40 pm
    Yep, I think I’m going crazy by now…
    but it’s true: load a still in the viewer from a bin and looks fine. Drop it in the timeline and luma shifts up. Cmd+1 back to the viewer, looks fine (luma drops to normal) Cmd+3 back to the timeline, up goes luma…
    I’m running FCS2 on an (yes I now) old dual G5 with Kona2, latest drivers, working on a KONA DVCPro HD easy setup, as many times before.
    It gets better
    If I double click the file to load it back in the viewer from the timeline (with the luma up) it will not drop it back, and will remain that way, the wrong way.
    The stills are generated in Photoshop (I’ve tried with PSD, PNG, TGA, TIF,…) with little luck.
    This never happened before and is not happening with video clips either (fingers crossed)
    I’ve trashed prefs and double checked as many things as I can think of but would do it again happily if anyone can help me with this.
    I will try to render clips from the stills in Aftereffects as a workaround, but rather try to fix the bug.
    Any clues?
    Many thanks in advance
    Chemix Ferreiro replied 17 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
