Activity Forums Adobe After Effects Viewer Settings
  • Viewer Settings
    Posted by Brian Hogan on August 21, 2008 at 2:11 pm
    Hi, I’m sure this is an easy fix somewhere for this but I don’t know where it is…nor do I know how this setting was taken off in the first place. But as of right now when I move anything inside the viewer window it doesn’t actually move with the cursor. A white outlined box moves instead and when I let go of the cursor the actual object shows up. It just gets a little annoying (especially when moving pre-comps) and I would like to change the setting back to the way where I would see an object move in real time when I pick it up with the cursor. Does anyone know where this setting might be? I’m very certain I did not change this setting and someone else actually got on my computer and started to view what I was working on. Unfortunately, this person does not know After Effects so it’s no use to ask him what he did. If anyone could help that would be awesome! Thanks.
    Brian
    Brian Hogan replied 18 years, 1 month ago 24,048 Members · 1 Reply
  • Brian Hogan
    August 21, 2008 at 6:05 pm
    Hi Dave,
    It was actually in the fly out menu on the timeline window. Thank you for your help!
    Brian
