Activity › Forums › Maxon Cinema 4D › Viewer keeps entering model
  • Viewer keeps entering model
    Posted by Ben Murphy on December 10, 2015 at 6:25 pm
    Hi Everyone,
    I am trying to work on a model that was imported as an OBJ created via a CAD program. Whenever I try and navigate around the model or move in close, I suddenly find myself entering INTO the model itself. Its not as if I am passing into the model when I move into to its actual physical boundaries, but rather whenever I move up to some arbitrary field surrounding it.
    For what its worth, the model is currently hollow.
    Any idea of how I can fix this? I have attached a still.
    Adam Trachtenberg replied 10 years, 9 months ago 3 Members · 5 Replies
  • Brian Jones
    December 10, 2015 at 7:30 pm
    near clipping on the camera (in Details) is what it looks like
  • Ben Murphy
    December 10, 2015 at 7:43 pm
    That’s what I thought was well. However, I turned off all clipping and it is still there.
  • Ben Murphy
    December 10, 2015 at 8:17 pm
    Figured it out!
    Turns out there is also a ‘View Clipping’ setting in the ‘Project Settings’. Set it to Tiny and back to work.
    Thanks for the help, Brian.
  • Brian Jones
    December 10, 2015 at 8:18 pm
    ah that’s the other place, thanks for the reminder
  • Adam Trachtenberg
    December 10, 2015 at 9:37 pm
    Probably be a good idea to scale that model up. When I import models I always try to remember to run the View>Frame Default command so I can see how big the model is in relation to Cinema’s normal scale. Super small or super big models can cause camera navigation and other problems.
