Activity › Forums › Apple Final Cut Pro Legacy › Viewer and canvas quality drop in Fcp7
  • Viewer and canvas quality drop in Fcp7
    Posted by Michael Bell on March 31, 2012 at 4:33 am
    I have converted footage to pro res 422 LT when I cut and transfer it to the canvas the quality drops and I dont know what to do what are the settings I need to resolve this issue its driving me nuts
    Michael Bell replied 14 years, 6 months ago 2 Members · 4 Replies
  • David Eaks
    March 31, 2012 at 9:11 am
    Exactly what was the video that you started with? Codec, frame size, frame rate? Same question about the Prores clips. What are your Sequence Settings?
  • Michael Bell
    April 1, 2012 at 10:43 am
    hi…The Profile settings on the converter are: Apple prores 422(LT), Size: 1920×1080, 25Fps
    The sequence settings are: Frame size 720×576, Aspect ratio: CCIR 601/DVpal(5:4), Pixe; Aspect Ratio:Pal-CCIR 601 (720×576), hope this helps, I know once its set I should never have to change it again as I will Be using the same camera, your help would be greatly appreciated.
  • David Eaks
    April 1, 2012 at 11:26 am
    Check the “Auto Conform Sequence” setting, in the menu Final Cut Pro> User Preferences> Editing Tab. Choose Ask.
    Create a new sequence, drop one of the Prores clips into the new sequence. When it asks you about matching sequence settings and external video to match the clips select YES.
    How does playback look?
    Again, what was the original source of video? A camera you’ll be using regularly right?
  • Michael Bell
    April 1, 2012 at 5:38 pm
    Hi….Great Thanks for that it works, the camera I am using is the Canon 600D
