Activity › Forums › Adobe After Effects › View Transform and Layer Styles in separate window
  • View Transform and Layer Styles in separate window
    Posted by Dustin Parsons on June 28, 2012 at 9:17 pm
    Is there a way to view the Layer Styles or Transform options of a selected layer in a window other than the timeline? I’m basically looking for a way to have it work like the Effects and Presets window so I can view all the info without having to drop down so many arrows.
    Dan Fredley replied 14 years, 3 months ago 3 Members · 3 Replies
  • Brian Charles
    June 28, 2012 at 9:21 pm
    There’s no way to see Layer Styles (or for that matter Shape properties) other than the Timeline, however you could apply the Transform Effect (Effects > Distort > Transform) which gives you access to all geometrics and more.
  • Dustin Parsons
    June 28, 2012 at 9:47 pm
    I was hoping that wasn’t the case. I wasn’t aware of the Transform effect though, I might give that a shot. Thanks!
  • Dan Fredley
    June 29, 2012 at 5:40 pm
    A couple of other suggestions:
    • You can Cmd/Ctrl+click any arrow in AE to open all child arrows in one click.
    • In the timeline search bar, you can open the properties you want to see by adding a comma in between search criteria. For example, “pos, rot, sca, drop” opens position, scale, rotation and drop shadow properties.
