Activity › Forums › Adobe Premiere Pro › View Program Monitor in External Monitor
  • View Program Monitor in External Monitor
    Posted by Zvi Twersky on May 16, 2007 at 4:39 am
    The guy that sets up out monitors doesn’t understand in computers and I don’t understand in monitors. He says that the little TV monitor is hooked up OK to my computer and if I don’t see my timelines playing on the external monitor, it must be some setting in the Adobe Premiere I need to set. I use Premiere Pro 2.
    IS there a setting to change in order to see my program monitor on an external monitor?
    Zvi Twersky replied 19 years, 4 months ago 2 Members · 2 Replies
  • Vince Becquiot
    May 16, 2007 at 5:48 am
    In order to see your preview window on an external monitor, you will need a firewire connection from your machine to either a Digital/Analogue converter, or through a DV camera, then to the monitor.
    Then simply go to the playback settings and enable external DV playback.
    Vince
  • Zvi Twersky
    May 16, 2007 at 6:37 pm
    Thanks, but the problem was I wasn’t opening projects with MATROX. Now it works.
