Activity Forums Maxon Cinema 4D View OBJ in c4d problem
  • View OBJ in c4d problem
    Posted by Jonathon Sendall on March 12, 2009 at 4:39 pm
    Pulled a model from Poser into C4D (v11) and when I try to view the model whenever I get close to the model it’s as if a 2D plane right in front of me cuts into it making the model dissapear. Tried looking everywhere for a solution but couldn’t find one. If the answer is simple apologies for the newbie question but I can’t find any answer in the forums that I’ve looked through so far.
    Thanks in advance.
    Story, not pixels.
    JPSendall
    Jonathon Sendall replied 17 years, 5 months ago 3 Members · 3 Replies
  • André Marques
    March 12, 2009 at 5:58 pm
    try to scale it a bit
  • Adam Trachtenberg
    March 12, 2009 at 9:56 pm
    Yep. Set your viewport camera to default and see how big the model is in relation to the grid. If it’s very tiny or very huge you can have these kinds of problems.
    FYI, you can change the default import/export scale for .obj files in preferences.
  • Jonathon Sendall
    March 14, 2009 at 1:28 am
    Spot on. Worked a treat thanks
    Story, not pixels.
    JPSendall
