Activity Forums Adobe Premiere Pro View in and out points within a TIF sequence on the timeline?
  • View in and out points within a TIF sequence on the timeline?
    Posted by Matt Chapman on November 16, 2016 at 1:24 am
    Hello all-
    we are working on a long animation and received 100+ new versions of scenes. Because it is an animation there are plenty of cuts and frame holds here and there.
    Is there a way to view the IN and OUT frames on the timeline of a TIF sequence? For the most part the timing of the scenes has been consistent, and we would like to match timing.
    Right now we are using 50% opacity to match frames, but it is time consuming. I would think there is a more efficient way, for instance seeing the TIF # of the IN point on a given event on the timeline
    thanks
    chapman
    Simon Ubsdell replied 9 years, 10 months ago 2 Members · 1 Reply
  • Simon Ubsdell
    November 16, 2016 at 10:00 am
    If you need to see the frame count of your image sequences instead of timecode, select your image sequence in the Browser and choose Modify/Timecode/Frames.
    Turn on Overlays in your Canvas and you will be able to see the frame count of your image sequence clips as they appear in the timeline.
    Also if you hover over a clip in the timeline, you will (after a moment) see the start and end frames and the duration.
    Does that help?
    Simon Ubsdell
    tokyo productions
    hawaiki
