Activity Forums Adobe After Effects Videosytle like A-Ha Take on me
  • Videosytle like A-Ha Take on me
    Posted by Berri5 on January 20, 2006 at 6:47 pm
    Hallo people,
    thank you for the support.
    I want to know , if there is a way to create a video style like this in
    the A-Ha video take on me.
    I have tried with Video Gogh but I failed.
    Please help
    THX Berri5
    Ron Lindeboom replied 20 years, 8 months ago 3 Members · 2 Replies
  • Chris Smith
    January 22, 2006 at 5:13 pm
    They most likely used a rotoscope to do that and did the drawings by hand. That and the howard Jones video with the same look.
    You could do this digitally. Use the paint tool in AE and paint strokes over the image. It’s gruelling work. Commotion has some auto paint functions that help out with this if you have a copy of it.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Ron Lindeboom
    January 22, 2006 at 5:21 pm
    I have also done this using a desaturate on the color, then using Find Edges to really push the contrast, posterize that, throw a crosshatch pattern on that and add some directional blur — then have same original image before all the effects were added on a layer above the effected one and use a blend mode in Multiply with an opacity that is just enough to add to the effected image layer and voila!, you can get pretty close to that look. (If I am remembering all the steps properly and in the correct order, it’s been quite a while. You may have to change the steps around just a bit.) ;o)
    I hope that makes sense, I am trying to do too many things today. ;o)
    Ron Lindeboom
