Activity Forums Adobe After Effects Videos are gettign skewed upon exporting custom export size
  • Videos are gettign skewed upon exporting custom export size
    Posted by Justin Sias on June 15, 2012 at 2:47 pm
    Hi. I am new to After Effects and I apologize in advance if this is a silly question. I have created a video in AE that will live on a custom monitor with target dimensions of 768px height by 1360px width. I have set the composition settings to these dimensions. In my render queue I have it set to export at these dimensions as well. I have experimented with locking the aspect ratio on both the output module and have experimented with the stretch option to try to force the video to export at the desired dimensions.
    The video export file’s info window says it is 768×1360, but when I view it in Quicktime and Itunes, the video is actually beign resized to 699×1360. When I open it in Adobe Media Encoder, it sees the file dimensions as 699×1360. The video looks slightly skewed and unacceptable.
    Can anyone give me any pointers to force AE to export this video at my desired custom width and height?
    Justin Sias replied 14 years, 2 months ago 62,714 Members · 2 Replies
  • Justin Sias
    June 15, 2012 at 5:57 pm
    Width: 768px
    Height: 1360px
    I’m not sure what some of the following mean, so not sure how I should set them, so any suggestions are welcome. but currently they are set
    Pixel Aspect Ratio: D1/DV NTSC (0.91)
    Frame Aspect Ratio: 1280:2497 (.51)
    Frame Rate: frames per second
    Resolution: Third (256 x 454, 454 KB per 8bpc frame
    The specs from client are as follows:
    Resolution: 768×1360 (wxh)
    File Type: .mov
    Codec: .h264
    Aspect Ratio: 16:9
  • Justin Sias
    June 18, 2012 at 12:40 pm
    Got this one sorted out thanks to a little help from my friends. The Pixel Aspect Ratio set to square pixels did the trick. It had to be done for every composition within the composition, and then export size ended up being what I had it set to in the comp settings.
