Activity Forums Apple Final Cut Pro Video Tracks in FCPX timeline
  • Video Tracks in FCPX timeline
    Posted by Glenn Pniewski on October 26, 2020 at 7:35 pm
    I am too used to FCP7! I’ve got three video tracks in the FCP X timeline and want to cut back and forth between them. In FCP7, you could lift a section off your video in track 3 in order to cut to track 2, and so on. I did my “lift” and it filled that track 3 section with a plug. But it’s preventing me from seeing track 2. If I remove the plug, it gives me a ripple delete. What am I doing wrong? How can I switch back and forth between tracks and how can i crossfade back and forth from these three tracks?
    Joe Marler replied 5 years, 10 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    October 26, 2020 at 8:08 pm
    Shift delete leaves a ‘gap’.
  • Glenn Pniewski
    October 26, 2020 at 8:21 pm
    Thank you sir. You’ve been my rock, reading through all these posts. . .
  • Joe Marler
    October 27, 2020 at 4:32 pm
    Glenn, if the three “tracks” (aka video lanes) are synchronized angles on the same event, it’s best to first create a multicam clip which is designed to cut between those angles.
    If it’s just random b-roll but you want dissolves or dip-to-black fades either between those or to/from the primary storyline, you can put those b-roll clips in a secondary storyline. IOW select the clips and do CMD+G. To revert it’s SHIFT+CMD+G (Break Apart Items). Maybe you already did that.
    If by chance you’re dumping a lot of stuff in various full-duration “tracks” to facilitate material selection, with FCPX it can be better to first curate and organize the material in the Event Browser, then query that and add connected clips as needed. However to allow transitions those would need to be in secondary storylines — where needed.
    One exception to that is continuous splitscreen (e.g, 2×2) so when adjusting timing all clips from each quadrant are locked to a specific lane.
    Maybe you already know this but here is a brief tutorial from Ripple Training about using alternate storylines: https://youtu.be/nGK3MFqohWw
