Activity Forums Avid Media Composer video track tabs out of order in my sequence
  • video track tabs out of order in my sequence
    Posted by David Ellis on September 17, 2008 at 2:56 pm
    hey weird question…..
    the video track tabs on the side of my sequence have gotten out of order. now my time line shows up as:
    V3
    V1
    V2
    A1
    A2
    my sequence still plays fine, but the video layer stacking is switched, and its just annoying. avid is not allowing me to simply drag the tab back to its proper place….anyone know a quick solution that i’m missing? thanks.
    Paul Nesmith replied 17 years, 11 months ago 5 Members · 5 Replies
  • Michael Phillips
    September 17, 2008 at 4:04 pm
    You should be able to drag it back into place, or use the “set default” in the timeline menu.
    Michael Phillips
  • Michael Hancock
    September 17, 2008 at 4:09 pm
    You can move the tracks when you hold Alt or Ctrl (not in front of an Avid to test it).
    Michael.
  • David Ellis
    September 17, 2008 at 4:14 pm
    right after i posted, i tried the alt drag solution and it worked! thanks
  • Terence Curren
    September 17, 2008 at 4:36 pm
    And this makes for great joke playing on other editors. Move a couple tracks around, then rename them so they show as if they are in the correct order.
    Of course I would never do this to anyone else, even if they did pull practical stunts on me all the time……
    Terence Curren
    http://www.alphadogs.tv
    http://www.digitalservicestation.com
    Burbank,Ca
  • Paul Nesmith
    September 17, 2008 at 9:39 pm
    Terry, you shouldn’t give away such valuable secrets!
