Activity Forums Adobe Premiere Pro Video stutter
  • Video stutter
    Posted by Eric Lemaster on May 13, 2013 at 4:37 pm
    I added this port to After Effects forum but perhaps it is better suited here?
    I have a video which consist of various panning shots. During editing and after exporting, I can play back on my 6 core 2.66 GHz 12GB 1333MHz DDR3 Mac with no problems. However, when I take the same export and trying to play back on a laptop or try to stream, the panning shots stutter – especially playing back with full screen.
    It is apparent that there is a issue with the redrawing, because everything on the screen is moving. I cannot seem to remedy the issue without seriously affecting the picture quality. I have tried exporting using many differently settings but no dice. Also tried the Warp Stabilizer.
    If anyone has any suggestions, I would be grateful!
    Eric Lemaster replied 13 years, 4 months ago 2 Members · 6 Replies
  • Kris Merkel
    May 13, 2013 at 5:51 pm
    Are you exporting out of AE through the render que or using AME to export your video? What CODEC are you exporting to? What are your bitrate settings ect.
    It is really hard to suggest anything without knowing specifics.
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
  • Eric Lemaster
    May 13, 2013 at 6:06 pm
    Thanks for the reply, Chris.
    I am actually exporting through Premier Pro CS6. I made a copy of this post over to that forum, as it pertained more to that product, and could not immediate remove this post.
    However, I did try AE Warp Stabilizer to try help the situation but it doesn’t help the situation since we’re talking about camera jitters.
    The video format is h.264, 1280×720 resolution, 29.97 frame rate, NTSC. Bitrate is set to 24Mbps for the target and 30Mbps max.
    I also tried using maximum render quality and frame blending, but no luck with that, either.
    FYI – Issue seems to be at worst during streaming from our Kaltura media server.
    Thanks again!
  • Kris Merkel
    May 13, 2013 at 6:30 pm
    Your bitrate is set too High. Your server cannot keep up with that. For web streaming you will only need a bitrate of 8Mbs max.
    I would try experimenting with lower bitrates until you find the sweet spot between bit rate, quality and file size.
    Kris Merkel
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
  • Eric Lemaster
    May 13, 2013 at 6:32 pm
    Strange, when I went to check it the first time, that what it read – which my thought was the same as yours. However, after doing a minor mod, I went to export is again and this time it readt 5Mbps for both target and max.
  • Kris Merkel
    May 13, 2013 at 8:32 pm
    How long is your video? If it is relatively short there is no reason to use VBR. Use CBR instead.
    Kris Merkel
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
  • Eric Lemaster
    May 14, 2013 at 12:54 pm
    It’s about 4min long.
