Activity › Forums › Apple Final Cut Pro › video stabilisation messing up sharpness
Posted by Mike Tyler on April 30, 2017 at 4:24 pmI was stabilising some footage with people (faces) in it and the whole video just looks bad and the faces blurry.
Is there a way to overcome this ?
How do you stabilise footage with faces in it ?Mike Tyler replied 9 years, 4 months ago 3 Members · 6 Replies -
Noah Kadner
April 30, 2017 at 4:37 pmDepends greatly on the degree of stabilization being added- it’s designed to help mostly stable usable shots not turn handheld into tripod. Share an example shot for more advice.
Noah
FCPWORKS – FCPX Workflow
FCP Exchange – FCPX Workshops
XinTwo – FCPX Training -
Mike Tyler
May 1, 2017 at 2:51 amok, so now I realised where the issue (probably) was..
There were a few frames where the face was out of focus.. normally, it was almost unnoticeable but with the stabilisation activated it was way worse..
Bret Williams
May 1, 2017 at 11:38 amExcept for the stabilization mode specifically called “tripod.” 🙂
_______________________________________________________________________
https://BretFX.com FCP X Plugins & Templates for Editors & Motion Graphics Artists -
Noah Kadner
May 2, 2017 at 3:35 amIt should be called wishful thinking… ????
Noah
Bret Williams
May 2, 2017 at 3:53 amWorked for me just the other day with interesting results. Now you have a shot with the foreground object locked off solid, but the background is somehow magically moving around behind it!
Mike Tyler
May 2, 2017 at 8:42 amunfortunately, the video wasn’t shot by me.. I was doing just the editing.
I was actually looking into buying a steady cam for moving shots.. not crazy expensive and pretty good results from what I’ve seen.
