Activity Forums Adobe After Effects video screens turn to reveal graphic
  • Vfxgal
    June 23, 2006 at 4:21 pm
    hi ,
    I was trying a similar effect except for roation part .I tried using the dissolve transition & it worked.Try using that one so that the videos once they rotate they could dissolve to show your graphic.Also I don’t know what your end graphics are like I mean videos forming into an image or videos forming into another video.Eitherways I think this should work. Another option would be to try masking the end graphic & aniamting the mask in coordination with your video wall.But thatis kinda tedious. Good Luck .Hope this helps.
    Cheers,
    vfxgal
  • Filip Vandueren
    June 23, 2006 at 4:34 pm
    If you make sure you pre-comp both your TV-screens grid and your graphic, there shouldn’t be any problem in using Card Wipe with the graphic set as Back Layer.
    so one comp that has all the different videoscreens side to side hugging eachother in a 3×3 grid
    the other comp has the same size as the first one, and contains just the graphic, large enough.
    – add a Card wipe on your tvscreens comp (rows and colums set to 3), you might want to lower the Card Scale so the screens don’t touch anymore.
    – hide the layer with the graphic comp, and select it as the Back layer in the Card Wipe.
    – animate your card wipe.
    same thing applies to card dance, if you need that much control.
  • Bonnfox
    June 23, 2006 at 5:32 pm
    Thanks for your suggestions and solutions. I’ll try both ways.
