Video Samples
Posted by Zeno Pierre on November 2, 2008 at 12:40 pmHi All
Are there any video samples of Media 100 projects anywhere?…highlighting it’s capabilities?
Z
Zeno Pierre replied 17 years, 10 months ago 3 Members · 5 Replies -
Wickham Strub
November 2, 2008 at 2:07 pmHi Zeno,
Funny you should ask. We’ve been working on that very thing for the last couple of weeks. We should have something available soon. While we’re on the subject, is there anything in particular that you’re interested in?
~Wick
Zeno Pierre
November 3, 2008 at 3:11 amHI, Wickham,
Thanks for responding to my post. I saw Media 100 for sell at:
https://www.digitaljuice.com/products/products.asp?pid=644It appears to have a building engulfed in flames but I can’t determine exactly what part Media 100 is playing in the effect.
If Media 100 can give that type of effect (building engulfed in flames), I would really be interested in purchasing it.
Z
Zeno Pierre
November 3, 2008 at 3:17 amOoops, my bad.
I was able to blow up the pic. I see now that the orangest red color was sun set not flames.
Butm still , I really would like to see Media 100 in action so I can determine what it is offering.
Z
Paul Crowe
November 3, 2008 at 9:44 amHey Zeno
here’s my two cents:
IMHO M100 is basically the best edit interface on the market. Over the years I have worked with Avid, Lightworks, Premier Pro, Final Cut and some others I can’t even remember the name of and I still think the M100 suite beats the rest hands down as an efficient, easy to use sound/picture editor.
Although I mostly opt to use Adobe After Effects for FX and Titling work the Boris suite which M100 comes bundled with will do what you need it to (based on the link to fire/sunset – burning houses in a wide shot). Now that media 100 will run, not only the same system but the same drive as the FCP pro suite you can even enjoy the delight of cutting on M100m and popping across to the Color for grading or tapping into any part of the FCP suite including DVD studio and Soundtrak Pro.
Hope this is useful
Cheers
Paul
